Exhaust seal ring
Exhaust seal ring
How do you remove this metal o-ring type seals from the groove they sit in? I blasted it with WD40 and PB blaster and scrubed it with a wire brush to clean it out around the edges, but I still can't get it out. Should I cut it up with a dremel? Or is there a little trick to getting it out?
made a groove with a dremel and cutoff wheel, then hammered an old flat tip screwdriver in the edge where it was weakened and pryed them out. piece of cake.
