Orlando dyno day results
Drive-by provocation guy
Derek: if you have an a/f controller, your chips do not have a bering on what boost you run or are mapped for. Turn up the boost, then add the proper fuel with the power pefect.
"2600-2800 rpm" that is why our curves look so differnt as mine is about 3,600-3,800 when it really starts to hit. So if we had 7K redline I would be set![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Duke: Yes, also MAF, injectors and 19psi.
A bigger turbo does not mean more hp, true, but compared to the k26 I should be making more as the 75 is more effeciant in the higher boost levels. Which explains why even at 6K I was still making hp.
As in Porshhhh John made 301/340 at 20psi on k26/6 with rolling off to 17-18. So that is like 70!!!!!!!! more tq he made then me at the wheels.
Something has to be wrong here.
Originally Posted by toddk911
"2600-2800 rpm" that is why our curves look so differnt as mine is about 3,600-3,800 when it really starts to hit. So if we had 7K redline I would be set ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
