NA heads 2.5 and 2.7
Rennlist Lifetime Member
The idea behind using an NA head is that without the ceramic exhaust liner, you are free to port both the intake and exhaust ports. I am not sure how much there is to gain there, someone with more experience can comment on that.
The 2.7NA head is used for 3.0 turbo conversions for a number of reasons:
1) Bolts onto 104MM bore block with water passage in the right location - no modifications necessary to fit to a 3.0L block
2) 951 intake manifold bolts directly onto the 2.7L head - no modifcations required to run standard 951 intake plumbing. And yes, it has bigger intake valves.
UAE Rennlist Ambassador
