Vitesse - New items
#77
John, Thanks for the reply. I've read posts where you said that your chips operate in "closed-loop". Is that all the time? Doesn't that mean that the chips are operating blind of the o2 sensor? Can you expound on that? Pros/Cons?
#78
I don't want to come off as even pretending to know the intricacies of Vitesse goodies, but I do know that closed-loop means he IS using the oxygen sensor (closed-loop in this case means feeding back the oxygen sensor signal to the computer). Open-loop means he is ignoring the oxygen sensor (i.e. he is running blind of the O2 sensor). I believe closed-loop is the way to be, and is one of the reasons his system lets you change boost level without needing to reprogram chips.
#80
Vitesse software operates in closed loop same as the factory did. Idle & PT are in closed loop. WOT is Open Loop.
