Coolant system evacuator/refiller opinions
I'm looking for opinions on a coolant system fluid exchanger, Need to work on p-cars, BMW and VW.
Anybody have one of these? Used one of these?
http://www.mityvac.com/pages/products_cse.asp
or
http://www.uview.com/cooling.html
Any else out there?
Thanks,
Jason.
or
Any else out there?
Thanks,
Jason.
What I did was just get an OEM resevoir cap and pulled the bottom part and spring off, then drilled a hole and put a Shraeder valve in it and used the tire pump. Worked decently, until I managed to loose the cap....
I did what Brian did but instead of a Shrader valve, I pull the overflow tube off and connect my Motive brake bleeder for a pressure source. I was afraid to use an air compressor and risk overpressurizing.
Lou
Lou
Also does it matter if you positive or negative pressure to exchange the fluid.
Thanks.
Jason
A Schraeder valve is what your tires have, it accepts a tire pump etc. to allow you to pressurize the cooling sytem. I use this method more to find leaks than actually change fluid. Gravity works pretty good for draining.
I did buy a vacuum style fluid changing system from West Marine. It has a manual vacuum pump and a couple of sizes of tubing you can push down a dip stick tube etc. It is great for changing oil in marine engines, lawn mowers etc. I also used to freshen the tranny fluid in my brothers Lincoln. It holds about 5 quarts, cost about $30.
Lou
Lou
