Antifreeze
I use the blue Volkswagon/Audi stuff because it's definately safe for aluminum engines. But with the German quality comes a kinda high price of $20 a gallon. Most of the other brands that are safe are red or orange, I just prefer blue cause it looks good.
I'm going with Evans NPG+ in the new iron sleeved block.
https://rennlist.com/forums/showthre...ns#post2513243
Pricey, but a lot of postitive benefits.
You've got a lot of choices.
VW/Audi blue (G11)
VW/Audi pink/purple (G12/+)
Prestone yellow
etc.
As long as it is phosphate free, you're in the clear.
I prefer the VW/Audi blue, since it doesn't match the color of any of the other fluids in the car. Makes it easy to tell what's leaking.
At one point I was running Amsoil in the motor, and dexcool in the cooling system. So, I had red oil, red ATF and dark orange coolant..... Bad plan.
VW/Audi blue (G11)
Prestone yellow
etc.
Originally Posted by 420WHP944
Thats what I'm planning on putting in my car when I get back to Ireland this summer, I've also heard great reports on it....how much do we need and how much is it a quart/gallon?
on this
I use a local brand that is phosphate free and "safe for aluminum engines & radiators", it is red (not pink or brown) in colour, like blood red.
I would not use what VW/Audi have (that pink stuff), it contains phosphate.
I also know that the 944/968 engines are extremely picky when it comes down to coolants, there was a thread not long ago on the 944 boards where a rennlister was replacing the headgasket and there was some pitting (or something like that) which was caused from the coolant.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
The Evans costs approx $20 a gallon – I used to think that was really pricey until regular coolant went up to over $10.
You will need just a tad over two gallons to completely fill an empty system. Get three gallons so you have some extra.
You have to make sure there is not water in the system – an earlier poster mentioned flushing the system with the sierra stuff – that could be a good idea. If you are putting in the Evans after a rebuild don’t forget to blow out the old coolant in the heater core.
Chris White
Chris White
Originally Posted by special tool
I use Pentosin.
JK- Lutjens
Regards
Ed
ps I was really thinking of going with the waterless ( Like, Chris mentioned, Evans )
My system is so dry ( 1 + yrs and counting )Its like Death Valley in there
Chris White
Chris White
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I switched to the Evans when I put in the present 2.75 liter sleeved engine in – I was also adding the Griffins radiator at the same time.
I like it a lot – I can take the radiator cap off and drive the car around with no problems. The gauge does not vary much from the lower line – but then again it didn’t vary much when I was running in regular coolant.
Would switching to Evans fix somebody’s cooling problem? Maybe, but personally I would fix the problem instead of masking it with additional cooling.
Oddly enough the big plus (at least the way I think) is the reduction in nucleate boiling and the lowering of the system pressure. At 15lb of coolant pressure it can stress hoses and such after thousands of cycles.
The draw backs – a little more expensive, its slippery as hell if you do leak any and since the fluid does not boil it will not evaporate – so if you spill some and it sits on the block above the upper balance shaft – it will not go away!!
Chris White
Chris White
