*OFFICIAL* Griffin Radiator Group Buy - Friday March 17th Ending Date!
#361
Originally Posted by JET951
how can the car run cooler???? the thermostat controls the engines tempreture, not the radiator.
the radiator just has to take tempreture from the coolant once the thermostat is open. so a silghtly lager radiator will cool that coolant slightly faster. although if the radiator is a little too big you will not get much flow through there.
so really the car should run at normal operating tempreture, not cooler.
#362
has anybody actually taken a before/after temperature to tell for sure?
also, one thing i've noticed is that the griffin radiator has less fins and coolant channels than the stock radiator. it would seem the stock radiator would be better at cooling, simply because it has more surface area due to having more fins and coolant channels.
#363
Originally Posted by nize
this is true. i think the people who think it's running cooler are suffering from the placebo effect.
#364
yeah, but you just admitted yours was defective to begin with.
has anyone compared a new (or at least not really old and crappy) stock radiator to the griffin?
i am willing to bet there is no difference in temperature, and that the stock radiator cools quicker due to having more surface area.
#365
with my 20 year old stock radiator the car runs on the bottom line. i really should replace it though, due to age. although i will be using a stock radiator.
