coilover questions
coilover questions
Hello
I have an '86 w/ a 2.8l motor and t3 turbo on it ~400whp, i was wondering what people with similar setups are running for suspension. I was looking at the JIC magic kit on LR's site and I was wondering if that would be sufficient for the track or if I should spend the extra money and get Ohlins or Penskes. Any input from any of you track junkies would be appreciated.
TIA
TIA
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
On a somewhat similar car (86 2.75liter, Vitesse stage2 – 400+rwhp) I have Leda coilovers (24 position adjustable) w 350/550 springs. Camber plates and some solid bushings. Nice for street and track.
BTW - I would recommend considering the 87+ conversion – that makes almost all 911 based wheels fit – much more choices, especial for track wheels. In addition the big red conversion is a better package for 87+ suspensions.
If you are at 400rwhp then the big reds will become a very good idea for track use. The stock calipers will work but at the price of a set of $200 pads per weekend…
Get the brake cooling ducts installed ASAP (OG Racing carries them)
Chris White
I drove a customers 350+rwhp with a stock turbo S suspension…really quite scary!!!
Chris White
Originally Posted by phillys4951
its not a full race car, just some track events hopfully
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Originally Posted by aeronautica86
in that case, the extra money for the adjustability of the more expensive units probably isn't necessary unless its just really what you want or have the money to spend.
(Statement of bias!) I am a Leda dealer (liked them so much I added them to the engine stuff I do). You can get a full set of Ledas for around $2500 to $3000 (there are many options) and the shocks are custom made to spec (valving to match springs).
Chris White
I agree with Chris and the others, for a part time track car the expence of the Ohlins or penskes is just not worth it.
I also run Leda's and Love them, they have been problem free for years. The single ajustables should suit you fine.
Wheels for an 86
Hi everyone:
I noted that some said that wheels can be hard to fit on an 86. Here is the link to the 10 spoke 18" wheels that I am using on my car. I am running 285-30-18s on the rear and have no cleraance issues.
Just an FYI
http://cgi.ebay.com/ebaymotors/18-Po...QQcmdZViewItem
Just an FYI
Originally Posted by 35thSLP
I just installed the Bilstein escort cup setup from LR and it is great! my car drives like it is on rails or as close to it as I care to get with a street car!
Drive-by provocation guy
How much differecne do coil overs make?
I have Knoi yellows and considered if I upgrade, I would go full coilover, but not sure if that is over kill for a 90% street car.
Is there a step in between something like Koni and coil overs?
In a street car I dont think its worth putting the money, the factory sys when in good shape is excellent.
If you track your car a lot, say 4 or 5 2 day events and are beyond the intermediate run group, it may make a noticable difference. to exploit it in the streets is kind of reckless.
I would definelty call it overkill on a street car.
Main benefits of the coil overs is ajustability, in dampning and ride height. You have to have a need to be playing around with the settings.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
400rwhp and stock suspension is a little scary, especially if the shocks are a little tired!! With mild mods the Koni Yellows will work well but once you get to the serious HP range you need to address the springs.
As for the rear coil overs – you don’t ‘have to’ remove the torsion bar but it sure makes sense to pull it out!
Chris White
Chris White
Chris White
Chris White
I just started yesterday the process of removing the torsion bars, and installing Leda's. I agree with Chris White, I think the benefits of completely removing the torsion bars far outweighs the cons.
