where can I get all the specs for an engine refresh?
I am pulling the head this weekend to see how the cylinders look. I am anticipating piston rings, rod bearings ( since I'm in there). I have been reading the haynes manual. From what I have read I need bore specs, piston specs, ring gap specs, torque specs on the rod bolts. This is my first time doing this. I'm all set with cold bevearges that will be close by.
If you have to bore, if your cylinders are scratched or are egg shaped, you will have to explore pistons options and that's not cheap. If you have to bore, you bore the cylinder to match the piston, which usually comes with rings.
Bret,
But I have to first determine if boring is needed right? I have to take measurements to determine that. WHat are acceptable measurements for bore, piston, ring gap, et., and where do I find this data.
Originally Posted by Alpine951
Bret,
You need to check it with a bore dial indicator. If you don't have any scratches you can get away without refreshing the cylinders (new rings) for a few years or IF the cylinders are good, you can pull the engine and just have the walls refreshed with the stone/felt/paste process from Sunnen and a good machine shop. If you have to bore it, you will need the next oversize piston(s), 100.5. Porsche are $1600 with rings, Tom C are $1100 with rings...+ shop work. Then add all the bearings, seals, gaskets...it starts adding up quickly but you will have a new engine to hopefully give you years of enjoyment.
