Who was building Intercooler hard pipes?
Originally Posted by danny951
What exactly is the "swedge" option on LR's hard pipes?
The website mentions it briefly, but it doesn't really jump out at you.
No swedge (stock style, use stock transition coupler):
With swedge (use straight coupler):
Drive-by provocation guy
How much heat would fins attached dissipate from IC pipes?
I see they have some models like that with internal fins, but about external?? I.e very small and a bunch all around the pipe.
Just talked to Mike L, look for Mike or Brandi to post up with info and conduct the GB on
www.turbo944.com.
www.turbo944.com.
Once I pick up a 951 I can make the pipes. Made the pipes for my Conquest and some friends cars, pretty easy - and my job (working under a machinist) has plenty of the right tools to do so.
Hey mike i think i live like 30 min away from you. I wont mind driveing up to you or you driving up to me and sizing them up. I have a stock set up if that matters or not. Not sure what you need.
See that is what I am wondering. Increase the surface area on the outside will create more cooling. The question is how much cooling?
IPSC
IPSC
IPSC
Originally Posted by DHC8FO
The way to go is to have a tube coil around the pipe that circulates water from the radiator, or a seporate cooler. That would really drop the temp.
IPSC
Geaux Tigers!
Originally Posted by ibkevin
I'd be interested for the right price, I don't need no stinkn' swedge.
