Cross Drilled vs Slotted vs Solid Rotors
Originally Posted by toddk911
And I have seen plenty of cross drilled/slotted rotors. i.e. they are drilled AND slotted.
Why would someone want to cross drill AND slot a rotor....the slot is simply there to get the gasses out which the holes will do.....
Someone with extra time on their cnc machining center looking for the next snake oil remedy.
Originally Posted by zerMATT951
Agreed. It's all for looks... just like painted calipers. "Look at my bling"
So I got a little bling but the calipers actually dissipate heat 20% better than uncoated aluminum....that is cause for a double!!
Originally Posted by sweanders
Please, don't post incorrect information. There is no such thing as cast holes - they are all drilled.
Originally Posted by RKD in OKC
Well, believe what you like from sales literature, I am reporting what I saw in person on my stock from the factory 2001 Boxster S.
Btw, the drilled rotors on a 951 do have ~40% more surface are which means that there is more surface area for heat to escape from. I believe that this is the main reason for drilled rotors, so if you never get your brakes really hot without enough cool down periods you have no use of the holes except for possibly a rotor with lower weight.
Drive-by provocation guy
Why Drilled AND slotted?
Drilled allows better cooling/surface area, and slotted allows trapped gases to escape easier.
Did you see the rotors being manufactured? There are different quality rotors but those that have holes are drilled, not cast. MovIt claims to have rotors with cast holes but I am not sure if I trust it since I don't know of any manufacturers that makes rotors with cast holes..
Zimmerman rotors do appear to be drilled.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
History lesson –
The first use of ‘rotors with holes’ was the 917 – it was done to make the rotors lighter – not for all the other reasons people like to make up.
The original Porsche 993 turbo rotors used with the big red conversions are cast holes. I use them for street and track use with no issues. They will develop cracks around the holes and eventually all the way to the edge (replacement time!) but this is under extreme duress. I get a couple of seasons out of a set of rotors.
Chris White
Chris White
Originally Posted by HIGHBOOST
If you get some rotors that are the same size as stock, but they are drilled. Then they will actually heat up faster due to the lesser mass of the rotor.
But keep in mind, if the rotors are in use on a car that is moving, and therefore having some airflow to and through the rotors, the convection heat transfer (cooling) is greater for the cross drilled rotor than for the solid rotor. This is because the holes increase the rotor's surface area which will allow it to transfer more heat to the air stream.
You would actually have to do a lot of testing under various conditions (distance, speed, ambient temps, etc.) and brake pad compounds to determine where the trade off is between the reduction in mass versus the increase in surface area with respect to the overall heat flux.
1 Post
Grassroots Motorsports has a VERY good article on this topic that takes all the guess work out of it.
Synopsis,
Drilling a rotor is for clearing moisture and contaminates (they cited mud/dirt form off road racing), also for lightening of a large rotor. With a huge rotor you do not need as much thermal capacity but do need the surface area for convective heat transfer. It is an engineering ballance and I dont think we have the ability to properly reengineer the properites of a rotor. They claimed there is very few vehicles that need drilled rotors.
Slotting is to wipe the pad of glazed (melted/burnt/galled...) material and allow gasses to escape. Grassroots claimed this is very useful and practical, it is also used frequently. (look at a bunch of race cars with iron rotors, they will have slots before drilled holes)
Plain faced rotors are just cheap to make and work for 99% of cars out there.
I was having a small problem with pad glazing. I layed out some slots on my stock rotors (symetrical and crossing multiple vanes) and cut them using a cut off saw and a guide. The performance increased and pad glazing was much less.
Synopsis,
The surface contact space with the pad on slotted vs. cross drilled should be similar shouldn't it? And crossed drilled should cool quicker than slotted since the holes go all the way through and allows more surface space when you figure the inside of the hole area. I don't believe the rotors are thrown away after a day of track use on the Carrera GT, 911's, or the Corvettes - at least not by the guys that come to the track with me. And if cracking were a problem with the cross drilled rotors I would suspect that the manufacturers like Porsche and Chevy would stop using them and go to a slotted or solid rotor. It seems like the people here that have slotted think they are best and people that have crossed drilled think they are best. I am going to stick with what Porsche and Chevy do as I think they probably know a little more about brake rotors than most of us here do.
Just my opinion.
Just my opinion.
First and foremost...thanks to all for your feedback...I apprecaite the feedback and hope that othjers are benefitting from these posts.....
So...at this point here is a quick summary of the varioujs posts:
* Slotted and Solids seem to be more ideal for "hard braking" scenarios - track events
** Cross drilled will perform better in wet weather, but may not hold up to track days as the slotted and/or solids will, they may develop hairline cracks.
*** Ceramic is not in the same category to compare, seem to be too costly for this comparison.
One observation I would like to point out is this....It seems that when you compare the type of rotors I have mentioned, using data points from "supercars" seems to be inapplicable. I am having a difficult time thinking about spending more than the typical price of a slotted or solid rotor from ZImmerman or Brembo. So, anyway, like I said, I am open to any and all relative feedback.
Thx again.....
Please feel free to add/update my summary.
Thx again.....
