Head Gasket News Flash
#32
Originally Posted by toddk911
Wow, so that blew out at several cylinders.
I guess that certainly proves more of a headgasket problem and not tuning.
Were all of the specific head smoothing/tq. specs addressed?? I assume they were but it seems from thier site that this hg requires VERY specifc instal/mounting guidelines.
the initial install for the cometic phuzion was performed by a porsche factory trained and certified specialist, so the install was not the problem. the problem was the gasket.
#33
Nize, you are talking about two different things (I think?)
You mentioned chris had used that technology that had the results in your pictures, however chris white's "new" technology he specifically states he has not tried yet, and is getting his first one later this week.
Not *positive* though.
#34
But is this the same technology that Chris is referencing???
if you ask chris, i'm pretty sure he won't recommend this gasket either.
#35
#37
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
It didn’t work for Nize, it work for me and a couple of others.
Nize gasket may have had an ‘issue’ since there were problems with the Cometic production machine when it was made. I (and nize) never got a good answer why it didn’t work.
My only issue with the gasket is that it is a one time use and a new set of the gas filled Orings is about the same as the whole gasket. I tend to take things apart (sometimes even just for fun!) and coughing up over $250 for a new head gasket each time doesn’t float my boat.
I would consider using one for very high output race engines where budget isn’t a serious issue.
One other issue – they only come in .060” thickness – this will drop your CR by .25 unless you machine the block or order pistons to match the gasket.
#38
Small Business Partner
Doesn't the extra thickness effect quench? What do you recommend for a quench distance?
Rogue
#39
All in all, it looks like these guys have some good ideas, but the material application at an early stage is usually crap.
So 250 for a 4cylinder? 500 bucks for a V-8. Hmm. Maybe not such a great buy.
BUT,
"Phuzion Requirements: Head and Deck surfaces should be within .002” of flatness and have a surface finish of 50RA or finer. The compressed operating thickness of Phuzion is .051”."
Some links for people that made them work ( i know, not conclusive)
http://www.cardomain.com/ride/369587
Never mind, can't find anybody else using them, other then another guy on some site saying they are crap, which means as much as the above no-comment parts list - nothing.
If MLS works normally, then I guess I see little reason
#40
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I still think it is a good concept but it is only (in my opinion) for all out race engines.
#41
This concept is not new. This has been around for years, maybe just never offered to the general public as an "off the shelf part". The old DFV had Cooper Seals fitted which are very similar. Many Turbo engines in the 80's had Compression rings fitted around the Cylinder Bores, held in place by the head gasket.
I agree that for the 944 type engines, the MLS is a very good solution and that most applications of this engine are covered by the ability of the MLS gasket.
#42
And if the MLS dosne't work this won't either (the main reason MLS gaskets don't work is lack of flatness/finish on the mounting surfaces).
#43
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Chris - what surface prep are you using for your MLS installations? What does 50RA look like?
An earlier post addressed change the quench clearance – its best to keep this fairly tight. The actual dimension depends on a lot of issues – rod stretch, thermal expansion, piston side clearance (more clearance = more piston rock)
