Piston Squrters for a 3.0 turbo block
As long as you get the ones that close if oil pressure gets too low. Otherwise, you may be increasing the chances of a rod bearing failure during starving for oil situations by having squirters.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
The Porsche and Kelly Motorsports squirters close at 3 or 4 bar, I can’t remember which. If you find some that do not have the spring loaded check valve – run away from those!
Chris White
Chris White
$50/piece seems high. You can get the following BMW squirters for ~$10/ea:
http://e30m3performance.com/installs...s-3/squirters/ (look at the 618 squirters)
Do you think these might work? ~$200 for the job versus ~$400 would be nice. I have heard estimates of 120F of cooling at the piston top. That is pretty significant in the world of detonation prevention.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Possibly, but the first guy to try will spend more than the difference to figure it out!
See if you can get exact sizes and I will compare them to the Porsche units.
