Why would my Turbo S run this cold?
UAE Rennlist Ambassador
Due to the lower weather conditions now, that is completely normal, since i get those tempreature readings as well.
Wait untill summer kicks in, you will see a totally different behaviour in the gauge.
My temp is in that range too, like said before I'd be more concerned about low oil temperature, It needs to be high enough to drive off any moisture that gets in it.
Welcome to Rennlist and Let be the first to say Nice Scirocco! Mods?
Originally Posted by jmporsche944
Thats exactly how my temp used to be.. now it runs like halfway for some reason. I dont know why.
Originally Posted by ehall
You don't need to test crap. The car is running just like it is supposed to. Time to find a real problem.
As for mods, the Scriocco has way too much to list. The main things are a built 1.8 8v GTI motor and custom turbo system I made with T3 turbo (50 trim/.48 a/r), Volvo 240turbo fuel injection. suspension and everything else too. Most recently I installed an LM1 wideband o2 sensor. It's very quick even though I only run 4-5 psi of boost. It feels a lot quicker than my new 951, but it doesn't nearly have the top end pull of the 951.
Scirocco is 2000lbs with around 150-175hp (stock is 74hp )
vs
951 is 3000lbs with 250hp
so that makes sense that the scirocco is quicker at low speeds but gets killed at the top end
My 951 also runs very cool. My temp guage is typically dead on the bottom hash and rarely goes above while driving. Lots better than running hot, which my 87 was prone to doing. You may want to consider adding an oil temp guage to help ease piece of mind concerning engine temps.
Seriously, if you just bought it and don't know much about these cars, get it checked out by someone who does.
My gauge has always been low like the one pictured, just below the first tick. If it got hot from summer stop and go, it would hit the first tick and the fans would come on. I have been concerned about it but it has been properly bled many times and always returns to the same spot.
Last season I did a DE in August and saw the gauge climb steadily through the session until it reached the second tick. It was then I was wishing it would run even cooler and was raising the hood in between sessions to start the next as cool as possible. I never knew that needle went that far up but it got some exercise that day.
Take it out for some summer track time and see if it still reads super cool.
Basic Sponsor
Great timing so I can ask a question. My car always runs with temp at the first line, but i just recently changed the turbo to oil cooled only. Now, my needle temp rests just a bit above the 1st line, my mechanic said to me that it is normal for the temp to go up a bit when you change to oil cooled only, is that true?
If your guy left just a little bit of air in the system, it could cause the entire system to run a little bit hotter. His reasoning sounds like BS to me.
Basic Sponsor
Lart it sounds to me like your mech failed to get all of the air out of the cooling system. Theoretically, the car should run a bit cooler without a water line running through the turbo. The water no longer has to circulate through the hot center of the turbo.
After many years of 944 driving and several thermostat/waterpump changes, my 2 cents worth:
Assuming temp gage etc. are all correct, running at 1:st line is a bit low.
It is most likely a sign of an old/leaky/tired thermostat and/or a leaky seal inside the water pump. This seal is what the thermostat seals against and it is glued or bonded or whatever onto the surface inside the water pump. It is not (normally) replaceable.
It is not really a big deal, but your engine will warm up slower and it will hurt your fuel consumption a bit. But, of course, it is nice to run things at spec......
I have exactly the same situation now with the Turbocab and I'm hesitating whether to replace pump/belts etc.
Good luck,
Tommy
Good luck,
Tommy
