Wastegate Dump to Atmosphere?
#47
Originally Posted by MPD47
Just FYI, I may not be in California, but my exhaust surely isnt legal. Keep in mind also that measuring DB is not linear.
pssh, hey, mine's not legal either. i see now that below the avatar it says NY. lol.
what's a good way to measure db?
#48
If you kept the stock WG cat connected and then put a fairly quiet muffler in back of that, wouldn't the exhaust technically be legal in CA, since you're not removing any emissions control device and you'd be meeting the noise limits?
Then you could remove the muffler for the track, assuming you met the noise limits?
#53
Originally Posted by 951Obsession
wouldnt boost bleed off have to correspond with how much backpressure there is on the WG and in the system in general?
all i know is i bled off ~7 psi before the dump, and ~1 after it.
When backpressure and the rear exhaust are discussed there are always theories but not so much hard facts.
We've tested without anything behind the cat and then with the OEM rear exhaust but with a straight pipe instead of the muffler.
HUGE difference in boost level using a MBC.
Had to turn the boost up A LOT to overcome the added backpressure from just the 2 angled and 1 kinked pipe.
You also have to keep in mind that the flow ratings for different pipe sizes are for straight pipes. When you add several angels and welds things change.
So....if you can... always GO BIG when it comes to exhaust
#55
OK i found a host for some of my video's.
Here is one from 2004 with WG dumping to atmosphere.
http://videos.streetfire.net/player....A-42EF3B713CFC
Same day but not opening the WG until the end.
part throttle driving
http://videos.streetfire.net/player....E-0243403BB57F
Heres one from this year with resonator installed to reduse sound.
http://videos.streetfire.net/player....4-291B7B35E28A
Heres one of me doig some donuts. with resonator.
http://videos.streetfire.net/player....6-8D11EE34BFFE
Enjoy
Enjoy
#56
honestly for some reason i just don't hear any difference running the wastegate to the atmosphere through the video's. i guess i am just used to loud exhausts and maybe that is where it is making the sound.
#57
Daniel,
In the first video, after i shift into 3rd, you can't hear the change in sound when i hit over 15psi.
And in the second video, you can ear the WG open barely in 3rd gear at the end.
I will get my other video tomorrow.
#58
Daniel, the second video where he is just part throttle is a good representation of what it sounds like closed dump, whereas the extra noise in the first video is a good way to think about open dump.
#60
Also I'd SERIOUSLY doubt 110db, and I have an open 3 inch pipe (no muffler) and an open dump.
As well as being non linear scale, distance has a big effect.
Noise is a big issue on UK race tracks and Ricks car would be thrown off on a 98dB day before dumping to atm.
Whilst 110db might be OTT I doubt it is below 100db even with trackside drive thru.
Quickest way to see if you like it is unbolt the wastegate exit, it will be loud until you get on boost (exhaust will leak) but it will be louder still once the wastegate opens.
Tony
