View Poll Results: Mahle Pistons 2.5L
I want 100.5mm?
0
0%
I want 101mm?
7
35.00%
I would buy a set (s)
8
40.00%
Not interested
5
25.00%
Voters: 20. You may not vote on this poll
Mahle 100.5 and 101mm Pistons
Look what Mahle sent me...one vendor is looking into this, I won't tell you his name or business but he is VERY respected here. They will be 8.1:1 CR and have Ferroprint iron coating. The estimated target price is less than $1300 with rings. That's all I know at this point. I have sent them a 100.5 to double check cc volume.
The reason I've kept on with this is that there are many blocks out there that can be saved, it is certianly cheaper than doing a 2.8L ( rods $1100, pistons $1450, 3.0 crank 1000-1500, plus added turbo/fuel system) and with the cost of machine work (avg $650 for bore/hone/finish alusil bore) you can refresh your old tired block for about $2200 including shipping the block. I'll tell you this, we probably need at least 17-18 very interested/committed people to make this happen. If you're not sure what size you would want, depending on damage, just vote that you would buy a set. TIA!
Just to throw out an idea, what about seeing if you can get them pre-flycut? Like what Laust did? It might drop the CR a bit, but it would definatly be a nice feature if it didnt significantly change the price.
The dish will be as originally done by KS. I thought about the cut but didn't want to get the price up to high or add to it. I think LR does this if you ask when they thermal coat the tops, not sure, but if we get into it and enough people are interested, we'll ask.
About a month or less after they get the order according to Mahle. They would be cut then coated. The rings and groves would be about .08mm less than the originals. The rest is basically how many people want a set or need a set. The minimum order is more than the 17-18 but in the discussion the other day, he hinted about that number to get it going, as it's a pretty good chunk of $$.
Hey Bret
I was waiting for a post like this from you for sometime now
Your awesome !!
best regards
Ed
ps what if one was interested in oversized ie
having a 3 liter crank What would be the req size and is there any shot
we could as for those as well if they differ in size to what your polling ?
TIA
Your awesome !!
best regards
Ed
TIA
I've got an engine that's waiting for a rebuild, but it's going to be waiting for a while. If these are still availibe when I actually get around to doing it I'm certainly interested. I didn't want to check a box, though, because I'm not committed to it any time soon.
The thing with the 3.0L crank is you really need Carillo or Pauter rods to miss the oil pan and the sides of the block, which adds $1100 or more and the crank. Here is a picture of Jim's 2.8 build with Carillo rods and 101 Tom C pistons. Take a look at the rod clearence
Originally Posted by Crazy Eddie
Hey Bret
Your awesome !!
best regards
Ed
TIA
Your awesome !!
best regards
Ed
TIA
