View Poll Results: Mahle Pistons 2.5L
I want 100.5mm?
0
0%
I want 101mm?
7
35.00%
I would buy a set (s)
8
40.00%
Not interested
5
25.00%
Voters: 20. You may not vote on this poll
Mahle 100.5 and 101mm Pistons
Originally Posted by Ski
Tom, yes these are just for 2.5 engines at the moment, stock length rods, no 2.8 stuff on the horizon at the moment.
Why the different ring grooves?
[QUOTE=Ski]The thing with the 3.0L crank is you really need Carillo or Pauter rods to miss the oil pan and the sides of the block, which adds $1100 or more and the crank. Here is a picture of Jim's 2.8 build with Carillo rods and 101 Tom C pistons. Take a look at the rod clearence
I guess that would count me out then :-(
Thanks Bret anyway
regards
Ed
Originally Posted by TOM M'GUINN
I take it these are replica 951 pistons in 1-over and 2-over sizes. You'd need to have the wrist pin moved up to work with the longer stroke unless you want to get creative with short rods. Otherwise, the pistons will rise 9.1mm too high -- redefining the notion of an "interference" engine.
Thanks Bret anyway
regards
Ed
depends on if the vendor chooses to do so but yes they should be available in the future, it's just that there is a minimum order capacity but I bet if he sells out of the first run he will get more to have on hand.
Why didn't this come together a year ago?!?!
Damn....
Can't buy pistons now.
Great idea however, best of luck with this.
I like the valve relief idea, definately worth it IMO. Lets you really stretch your timing belt change intervals without worry. Exactly what skirt coating would be used?
Damn....
price target is less than $1300. coating will be Ferroprint iron coating, similar to Ferrostan(original) but the waste from coating process is more evironmentally friendly.
Bret,
Just posted my "yes" vote (would actually prefer a set of 1st overs but would probably take a set of whatever the first batch was).
Funny this came up now... I stumbled across your old, original post on these a couple of days ago and almost dredged it up to ask if it ever went anywhere... good timing!
Don, Jim and myself are about to do two engines in two different locations - one in Corpus and one in Heber. One guy got the Tom C pistons the other wanted OEM if we needed them and could find them, so I got on the phone.
Originally Posted by Skunk Workz
No 97.1mm stroke 3-liters out there... ... - 4.55mm interference engine isn't much better though...
Originally Posted by Jon Moeller
Sorry, Bret, I was actually asking 420WHP.
420, how much for the used 100.5's?
-J
-J
i'll take $200 plus shipping for them.... if you are interested pm me..thanks.
