Intercooler Sprayer
![Lightbulb](https://rennlist.com/forums/images/icons/icon3.gif)
Has anyone here tried to use nitrous to spray down the intercooler or even spray into it?? I have a 2 stage NOS kit from my old Mustang coupe I could break up an use to spray the intercooler.But, Im not sure it its worth the trouble??
That Guy
The problem with the stock 951 intercooler is that it gets a lot of heat soak. It has very limited air flow so it traps a lot of heat. Getting a vented nose panel would be the first stage to reducing the amount of heat soak. Next would be an intercooler sprayer. I have a water sprayer set up right now.
since you have the system just lying around, go for it,It will make a difference theres no doubt about that. I just don't think you will notice it all to much driving around.
Drive-by provocation guy
Now, as just spraying the IC you are fine, but if you choose to inject at the IC, then, you have some tuning issues to address.
Mexican Ambassador
i always thought about doing this, but how long does the effect last? i mean, assuming you have a vented header panel, and the intercooler sprayer, how long until it just soaks up again?
what happens when an intercooler gets really heat soaked?
Would be nice if you could use that system, but instead of that Loop piece, use a similar piece of small piping and completely wrap the IC pipes and possibly the intake. The you would be running a contantly "chilled" IC and intake manifold.
