Front Suspension is making a LOUD creaking sound...
Remember when buying "rebuilt" control arms, most rebuilders are still machining out the pockets and pressing in aftermarket ball joints. This thins the aluminum around the ball joint and causes a weak spot in the arm.
When you rebuild the arms yourself using a kit, it is returned to OEM spec and the arms are not weakened.
