Wide Fender & Rear Body Kit For Rolex
To All:
I just started doing some research on this and wanted to get alot of people's opinions on this. I don't know, maybe I should have created a poll instead?
Anyway, the only reason why I'm going to consider this is for traction purposes only, not cosmetic reasons per ce. But obviously the wider parts will make the car look different to some degree - good or bad I don't know. So I'm looking to see if people can help me here by posting some pics, and giving me their thoughts on how a wider fender & rear body kit would look on a street car. I know these kits are used often for race applications, but as I said, I'm contemplating this because I want to be able to put wider tires on in the future. Thanks everyone in advance for your help.
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
Rob,
The only problem is the finish, its hard to make it mint. Plus you will need some type of fender lining because, when a rock gets kicked up, it will spyder the paint.
AIR parts are nice.
AIR parts are nice.
Did you see this car when at Lindsey's ?
http://www.lindseyracing.com/project/page2.html
I agree with evil 944t, it will be hard to get show quality like the rest of your car.
With the correct offset, some pretty massive wheels can be fit under the stock body for a mostly show/street car.
With the correct offset, some pretty massive wheels can be fit under the stock body for a mostly show/street car.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Evil: I know, I was thinking about the paint matching with the rest, even though I have an awesome auto-body shop. And I was just going to do the fenders, not the whole car. And I didn't know AIR made them too? I only looked at GT Racing.
Have either of you guys seen this on a street car? Thoughts?
I have seen an AIR widybody trackcar rear end. It was real nice. They had a custom front end.
You can get it done real nice. It just takes alot of time and money. I have no doubt it can look like a factory job but you will pay.
The front end of my car looks awsome (gaps and paint) but has cracks in the paint from stones getting kicked up in the wheel well. I have to build an inner wheel well.
There was a guy on eBay who had his 2.5L posted last week. I saved some of the pics he had. He had a widebody, but just in the rear, the front was stock. When I get home later tonight, I'll post them and you guys can tell me what you think. It's just hard to tell even with the pics. I guess I would need to see it in person. Oh well.
You could always have your fenders heated then rolled and stretched out a few more inch's ive seen this on 1 other 951 and i know the VW crowd is known for doing this. It looks really good when done correctly.. No wide body glass parts needed although the 968 TRS wide body flair extentions with rivets are hot.
How wide were you contemplating?
Its certainly possible to run a 315 with the right wheels and stock fenders. With a little gentle rolling, an even wider tire is possible. Or maybe without?? Anyone have a fix on the widest wheel & tire combo that will fit with stock rear fenders?
One caveat on the answer. The largest wheels that will fit on my car [with 1000# springs and lots of -ve camber] may not be possible on a street car with lower spring rates and less aggressive camber settings.
As I just posted above, that fender rolling sounds like it may be perfect for me. But I just don't know 1.) who would do it. And I would like to see if some one has pics of this, before and after? 2.) I have no clue what size I could fit in the back, give my rim off-sets, rim sizes, tire selection with this fender rolling process? But this fender rolling sounds like it could be the "best" option for me.
And even with the recommendation of the 285s for the back, I still don't think they will be wide enough to help me put down the traction. I've heard I "may" be able to fit 295s given my configuration; but that's a gamble I'm not sure I want to do.
Not sure on early turbos but 295 will fit on 88-89 turbo S. I might even tempted to try an dfit 305s without mod. I have a picture or link somewhere that i posted a few months back of how it looks on my car.
Whatever you do, DO NOT use fiberglass on a street car. Metal is fine, but that's it.... You might be able to run 305 on a narrow body with custom wheels and stiff suspension...
