oil cooler
Quote:
Originally Posted by jimbo1111
I recently replaced the oil cooler housing gasket and orings because of an oil leak. First time I ever saw an external leak on 944 t. You might want to look at that as well.
Is this a pita, how long did it take u to complete the repair ?
Any tips not in clarks. I need to replace motor mounts, struts, and fix an oil cooler leak. Would it be easier/better access if all were done at the same time ?
thanks
red 86 951 stock
thanks
red 86 951 stock
If you need to jack up the engine to replace the engine mounts, this would allow you to take the exhaust header off the studs and give you a little more room to work. I'm told it's possible (and about to try) to get the oil cooler housing off without taking the header off.
UAE Rennlist Ambassador
