Guess my whp
Guess my whp
Ok I sent my car to get dyno tuned since I don't have any time anymore and I was wondering if you guys could give me an estimate of where my whp should be.
Hans - I don't know if I understand you correctly.
I am sure you know that a small turbo (like the stock) will be making much hotter, less dense air at 15 psi than the larger Vitesse stage 2 at redline on the same engine.
Offcourse, agree. The stock turbo will just produce heat if boost levels are increased. But also it does not maintain boost pressure to redline.
But I doubt that at 15 psi there would be a world of differences between the various turbos that can maintain boost, from our own experience this becomes part of the equasion at 18psi+
From past posts I believe the stage 2 should be around 300rwhp at 15psi on a dynojet. Other dynos may refect a 10hp +or- differents.
