Clutch Pedal problem
My clutch pedal just started acting up. It doesn't return all the way after depessing it. It returns enough that the clutch engages. If I pull it up with my foot it returns all the way.
Is there a spring or maybe bushings that could go bad?
UAE Rennlist Ambassador
Could be the clutch master cylinder itself, stick you're head down to where the clutch pedal is, look for any signs of a leak or wet rubber boot on the clutch pedal rod.
Former Vendor
And if neither of those cylinders leak,check the hose from the master to the slave,a friend of mine had a leak in it. We discovered it after changing the slave cylider...
Assuming its the hydraulics , do yourself a favor and replace all three parts at once -- master, slave, line between them. New parts tend to blow out old parts -- they like to get old together. I replaced the master. Then the slave. Then the line in between. Bleeding is a real pain, so the fewer times you have to do it, the better.
