Which Fuel Pump ?
#31
The Lindsey Bosch HV is a good stock replacement pump. Follow the link provided by Darklightening and you'll see the HV is only good to 400 crank HP.
then how did dave make 460 at the wheels with it with no pressure drop? that is nearing 550 at the crank. looks like someones wrong. rob made 460 at the wheels to.
Wes
Wes
#32
Wes
Wes
And regarding Darklighing and his chart, well, I seriously question his validity. Why? This is the same guy (this is a fact, no BS) who came onto Rennlist and posted that thread about "Pro-m is back" and that his company was a dealer, with "an inside connection too". And anyone who followed the thread saw at the end that the new owners of the company said they had no idea who he was, and that he was not a dealer too. That being said, I seriously question anything he has to say. The facts are the facts.
Bottom line? If you're going to make some "big powa", you're going to need a pump that can support a car that will be driven for alot of miles, for alot of years, and/or sustained periods of usage. And my answer, well, as some know I went with the #044, and I have more than enough in that pump itself.
#33
Wes
Wes
Right, with 55 lb injectors. I am still waiting to see the AF and boost log from that run. Do you know what he had his AFPR set at? Just because something has been done does not mean that it is optimal.
On a turbo car, max'ing out your fuel pump or running injectors at 100% duty cycle are bad ideas. You are just asking for trouble. Give yourself a little extra and you will never be sorry. That is my opinion.
#34
your taking my comment wrong. i wasn't saying that it was the best pump to run at 460 rwhp on
a track constantly with safetly. maybe yes. maybe no. i was saying it is more capable then 400 crank. and posted two examples.
Rob, i remember you posting a dyno chart with your car making way way over 500 rwhp on the HV pump after you had it tuned someplace. how much was that again? i could not find the chart.
I made 415 rwhp on a 170,000 mile stock pump and it didn't run lean. is that a good pump for a track. no. just showing that it can make that hp.
Wes
Wes
#35
ted. on that day we were not shooting for 460. rob wanted a 400 chart. we kept inching things up
andgot 460 at 18. i cannot remember the pressure but im sure it was high. rob was going
to run the car at 15 psi if i remember so it didnt mattter.
Wes
Wes
#36
Wes
Wes
EDIT: By the way Wes, tell everyone at LR that they have a nice ad in Excellence this month. You guys have a nice creative piece that features the LR car that made 479 RWHP. Very sharp!
#37
Originally Posted by RolexNJ
For sustained used, thats playing with fire, period.
So you're saying that the HV pump can not support a sustained ~350 rwhp (400 crank)?
#38
From what I do know, the 928 GTS pump would be able to support a 400 BHP level. Personally, I would feel comfortable with that pump for 400 BHP. Someone on the thread talked about flow rates, you should refer back to that.
#39
UAE Rennlist Ambassador
Stumbled across some useful info.
I sourced the Bosch 044 Mostorsports fuel pump, Bosch part number 0 580 254 044, Porsche part number 993 620 104 80
It supports 750Bhp (flywheel power)
And i sourced it for US$200, this is not a Chinese knockoff, but the Genuine unit itself.
