I thought you guys might appreciate this more...
The 928 calipers I'm thinking of are 928-351-423-03 and 928-351-424-03. 928 GTS...I was confused.
Tim, yes the brake ducts scoop air from under the car and direct it to the rotor through the plastic piece mounted to the strut. It's a great set-up for the S2 since it does not have the 944 turbo brake ducting running from the front through the wheel well.
The cover is the same but the turbos have the ducts that bolt to the underside and go through the wheel well. On the S2, the oil cooler is in the way on the passenger side..it's longer than the turbo's so I guess it wasn't an option. The batwing is also different on the turbos to acommodate the ducts.
Originally Posted by Ahmet
(I can lock up my R comps on 8 inch wide wheels all around on a non MO30 brake car w/race pads from 130mph, consistently and it was a modified turbo not a stock S2),
Aribop, you are going the right way and doing the cooling first. With the proper cooling and pads, the stock brakes are probably more than you will ever need. However, I say still upgrade.
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
Oh and the big black 928GTS brakes are the same as the 993 TT other than the color. (The 993 also used a different rotor, but they are interchangeable.) The 928s4 brakes are not big blacks. They are the same as 951S brakes.
What does being able to lock up the brakes mean? I could probably lock up 305 hoosiers at 130 mph with 914 brakes.
That doesn't mean anything on the track. The reason we get bigger brakes is because more surface area = less brake fade. In other words, it will take the brakes longer to get hot.
Aribop, you are going the right way and doing the cooling first. With the proper cooling and pads, the stock brakes are probably more than you will ever need. However, I say still upgrade.![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
I agree with the second paragraph I've quoted from you. Cooling is key, and with proper cooling, even factory brakes (-pads and fluid) will be more than adequate on any street legal S2 that doesn't have forced induction or otherwise a very heavily worked engine. I agree with all of that second paragraph, but the last sentence... Well, bigger brakes DO look better!
Ahmet
Campeck Rulez
Ahmet
Ahmet
heh.
and I dont see why everyone has it in there head that if your engine is puny you arent allowed bigger brakes...
and if your engine is beefy, you MUST have bigger brakes.
![order](https://rennlist.com/forums/graemlins/order.gif)
Oh c'mon, an S2 is not puny. I'm just saying that (in my opinion anyway) going beyond MO30 is overkill on one. The benefits do not outweigh the costs. Ofcourse, it comes down to preference...
Ahmet
Ahmet
