Alternative Header Options
I did check all bolts that appeared like they had any remote association with the pipes, and everything was tight, in fact, I had to use a fairly large breaker bar on almost all the bolts I actually had to remove. I suppose there is a chance I could have missed something, seeing as I did overlook the bolts that mount the oil fill tube heat shield.
Here are a couple of pics of that 100 dollar miata single-piece header I was talking about. It was actually 150 shipped, from ebay. He got the pipe knowing it would be marginal quality (we're both college students, so there's financial reality), but the only area that seems to need addressing is the porting where it meets the cylinder head, which he plans on having cleaned up at a machine shop. I'm not a metallurgist, so I don't really know the specifics on the metal, but it is a fairly thick mild stainless of some sort. Definitely a superior design over the stock.
I would love to see a more reasonable aftermarket header/crossover, but..... just the 4 into 1 collector is $400 from Burns stainless, so I don't see any "cheap" options possible.
Is'nt Lindsey working on a header/crossover ?
I'd pay you $150 to through that thing in the garbage.... just kidding. You can't compare F-bodied cars and Miata's to a 951. There are way more of those cars out there than 951's. The more cars out there, the more people supply parts for.
I don't see how you can compare that to a SFR header. Different material, quality and parts.
For someone to make a header in there garage like a SFR header, would require $2-4k TIG welder, a 220v outlet, someone to pay for electricity, the stainless bends, a notch maker or lathe, belt sander, a machined single flange or 4 independant flanges ( something you or a machineshop would have to mill for you ), Welding rod, v-band clamp, turbo flange and wastegate tie in.
On top of that, you have to know how to weld.
SFR and Lindsey etc.. also have to pay for overhead, marketing, saleries etc..
Most of the capital items you listed above are ordinarily hired, not purchased. The knowledge, well, there's an exception.
I'm not picking on you, I just wanted to let people know that not all items are cheap to make, some are but, headers aren't.
I think most people don't want cheap products, they just want cheap parts. We all know, you get what you pay for. As far as headers go, as you know, they are under serious heat and stress. They need to be built right.
As luck would have it, I am going to build some header/crossover pipes soon. There is a good chance I might offer them for sale too but they won't be low quality and they won't be $150. More in the range of $1500. 321 SS, v band etc..
Originally Posted by RolexNJ
Yes they are, but not as of yet. Before I bought my headers, I looked into a few companies. After reading alot of threads, talking to some other people I know, and definately the test in European Mag, I decided to go with the SFR Stage 2. He also makes a Stage 1 which I believe is cheaper. When it comes to headers, bar none (so far) Tim's are the best made and gave some respectable RWHP too. I have the Stage 2 on my car. Special Tool has either the Stage 1 or 2 on his, but I can't remember. Also, I've heard nothing but bad things about the Broadfoot ones. That people actually lost power, let alone that the company is next to impossible for customer support.
![Talking](https://rennlist.com/forums/images/icons/icon10.gif)
I'm just trying to tell you why the costs are high. You can buy the stuff and do it yourself or pay someone(who bought the equipment) $80 per hour to do it.
It'd just be nice to get some cheap headers to get me through a year or two, which equates to about 5,000 miles (if that) for me. In the meantime-- anyone selling a crossover pipe? I have some nice '86 offset turbo fuchs....maybe some closer shots would entice.
Originally Posted by juanchovidal
Call Dr.mechanics (787)525-6064.
I give him my stock headers for free.
Tell him to give you his.
They are not perfect but pretty good.
