Early steel a-arms on 86 951
I would like to install new early steel a-arms on my 86 951. My questions are, What other components are needed, and I want to know how to reinforce the a-arms for track use. I have the sperical bearing kit from Racer's Edge, early bearing kit to be used with steel arms on an 86 951 w/ stock spindles/brakes/wheels...
You will need the early sway bar mounting brackets as well, they mount differently on the alloy arms.
You can run a seam weld along the valley of the control arms two stamped pieces.
Im in the process of this myself, but im using urathane bushings all around.
I have this setup on my SCCA ITE 951 and I'm very happy. I reinforced mine with steel brackets welded along the outside seams. Also I've drilled holes through them for the sway bar links and reinforced them with large welded washers. I have Weiltmeister urethane bushings at the moment but I plan to go with the Racer's Edge spherical bearings for next year. As eclou said, pair of caster blocks from a 924S or a pre-85 1/2 944 is needed. By the way, I know of several 944's racers that have been running on unreinforced steel control arms for years without any issues.
