Part name?
#31
Basic Sponsor
Originally Posted by ehall
Those two studs go into that particular camber plate from the bottom and then bolt on top. I would ditch them, unless he sold you the plates, and buy the KLA monoball set for about 115.00 from Paragon.
http://www.paragon-products.com/product_p/kla_944sm.htm
or buy replacement bushings for the stock upper mounts here:
http://www.paragon-products.com/prod...343.071.00.htm
unless you race, or just want some bling, you don't really need camber plates, because once you have everything aligned, you won't have much need to adjust anything.
#33
Damn LArt. Was there a massive coolant leak, or did they intentionally paint it that color? You better be fast to drive that sucker! What is that color called? Prestone yellow?
#34
Basic Sponsor
