question about stock boost gauge
what does yours read at idle ??? With very fine adjustment with my TPS I can get it to about .5 now should it be at .4 ??? Besides the KLR line is there any othe vacuum lines going into the car ??
I think it varies based on location, altitude, etc. and how warm the engine is. I'm not aware of any other lines going into the car other than the ones on the rear firewall that have something to do with controls on the heater and a/c inside.
1 Post
If it reads 1 Bar at idle, you have a serious vacuum leak. I don't look at the stock gauge anymore, but my ZT-2 shows ~18 in hg which is ~0.6 Bar. This means that the stock gauge should be at max vacuum (all the way to the left).
Mexican Ambassador
yeah, mine reads at the first little bar from the left when i first start up the car, after that, it reads all the way to the left at idle. 1 bar at idle cannot be good....
Alex sorry to hear about your car.....as for me getting closer to ahappy point. Still little things that get to me....suspension needs setup and now a coolant leak after i had it bled at nordan. As usual car is there not getting in due to others cars going in first. 944's the basterd child. So what your plans with the car ?? I was going to see if I could borrow your klr and me to see if any thing changes in my car.
