Race Part for sale
5th Gear
Race Part for sale
968 Gearbox with GT-3 RS Limited slip differential with new synchoniz $4,200.00
QUAIFE TORQUE BIASING DIFFERENTIAL for 944 transmission Two race only $850.00
BBS tree pieces wheel gold 10” x 18”(Set of 4 wheel, 10” each corner for 1988 ) $1,880.00
PowerHaus K-29/8 Turbocharger Conversion Two race only $995.00
Recaro Pro Racer SPG - Hans FIA Rated Black W/BASE $800.00
-SPARCO PRO 2000 RED COMPETITION SEAT W/BASE $350.00
-New Mahle 2.8 Stroker Piston PS100-008 100 mm 34.3 cc bowl $995.00
-New 3.0L crankshaft. Brand new Genuine Porsche race prepared lightweight
Crankshaft with 10 lbs cut off, cross drilled & balanced, Magniflux, Knife edge $2500.00
Fuel Cell (no modification require, located in the same location of the factory ) 17 glns. $895.00
ATL 2 ¼”Female, Male Dry Break Valve & Discriminator Valve 1.50” $380.00
Bilstein Front valved 600/180 Coil-over fronts struts are ride height adjustable $400.00
Bolt-in Roll Cage Kit white $400.00
A-Arm Monoball Caster Blocks - pair $200.00
Kokeln Competition Shift **** $100.00
Kokeln Short Shift Lever New $160.00
WELTMEISTER 944 ADJUSTABLE CAMBER PLATES $250.00
993TT FRONT BIG RED CALIPER(with piston & seal) pair $500.00
Big red Caliper Adaptor Kit pair $100.00
944 Rear Bumper save 27lbs Fiber Glass GT Racing $150.00
Carbon Fiber Dash $180.00
Firebottle 10lb Electrical Halon System $350.00
For more information please call JB at (787) 642-2253 or blanco@artdraft.com
blanco
Sent an email ...
Never heard back ???
Please respond when you get a chance
Regards
Ed
Sent an email ...
Regards
Ed
