Best mod yet! S2 ring and pinion
Old 10-14-2005, 11:15 PM
thingo
thingo's Avatar
I am just trying to convey information, I mean 944S, it is stronger than the S2, if I am incorrect, apologies, my mechanic has a lot of experience and would not encourage me to buy something not strong enough.
Old 10-15-2005, 01:33 AM
DFASTEST951
DFASTEST951's Avatar
And here's me trying to figure out how to get a much taller first gear as it's completely useless. Second isn't much better as I spin em' into mid third. Since we're on the subject, anyone have an answer? I want to get to 60mph in first gear. If the new vettes do it, I want to as well.
Old 10-15-2005, 01:40 AM
TRWright
TRWright's Avatar
Joe, you can get to 60 mph in first gear!! You just need to downshift!!
Seriously though, doesn't Powerhaus make custom gears?
Old 10-15-2005, 01:44 AM
RK951
RK951's Avatar
Iis the R&P from an S2 different than the '88 951S or '89 951?
Old 10-15-2005, 01:48 AM
NZ951
NZ951's Avatar
Ted, you are confusing Powerhaus with PowerhausII
Old 10-15-2005, 01:50 AM
TRWright
TRWright's Avatar
OOPS! Are you serious though? There is really a difference?
Old 10-15-2005, 01:53 AM
NZ951
NZ951's Avatar
No I thought it would be a cool joke.
www.powerhausII.com
Old 10-15-2005, 02:11 AM
DFASTEST951
He's serious Ted. I've contacted PowerhausII. They talked to me about what I want to the tune of 25 grand. There's got to be a better way...
Old 10-15-2005, 02:39 AM
z3bra
z3bra's Avatar
Well here's the ratios on the C6 transaxles That's why they get to 60 in first.
Gear ratios auto 6spd Z51 pkg
1st gear 4.02 2.66 2.97
2nd gear 2.36 1.78 2.07
3rd gear 1.53 1.30 1.43
4th gear 1.15 1.00 1.00
5th gear 0.85 0.74 0.71
6th gear 0.67 0.50 0.57
Reverse 3.06 2.90 3.28
Final drive 2.56 3.42 3.42
(sorry for the crooked formatting there)
Guess you could get a hold of Powerhaus II or swap in a vette transaxle. The Vette one would handle the power you're putting out better and you'd get a relatively inexpensive 6 speed out of the deal. Maybe not a bad idea at all provided it can fit without major modification of sheetmetal. From a couple pictures I've looked at though, it looks like the axles come out toward the rear of the housing instead of toward the front like they do on our cars. If not there's always something like Hewland if you don't mind dropping $20k on a hardcore racing transmission.
Ok scratch that, I had to go and look, the Hewland NLT transaxle could probably be fit into a 944T pretty easily. It's a nice 6 speed sequential transmission with a semi dry sump oiling system and it does have reverse even which isn't always available on a racing transmission. It can be yours for a mere $24,250.00 at the current exchange rates or if you want it with a magnesium housing it'll be $26,206.00. At $24k, I think I'd drop the extra two thousand for the magnesium housing, why the hell not. The downside of course is that it's most likely straight cut gears and doesn't have syncros so it's going to be a tough, but noisy SOB. Since it's sequential though, you could actually have a paddle shifter 944T and that alone would kick much ***. Of course there's always the installation labor to figure in and the other parts you'd need to adapt it in. Probably figure another $10k or more for that. I believe with the ratios available though, you could have 60 in first like a vette and this transaxle is a pretty good match dimensionally for a 944T.
So since you don't want to pay Powerhaus II $25k I'm guessing you don't want to pay $35k for a Hewland box either.
Maybe a G50 transaxle from a Carerra could be adopted for less, you'd get the 6 speed that way and just from the economy of scale, gears changes for a G50 from Powerhouse II are probably considerably less money. Just a thought anyway.
In the unlikely event I win the $300 million powerball jackpot Saturday night though, I think I'll buy a Hewland box just for ****s and giggles and to have the only sequential shift 944 Turbo I know of. (Yeah someone's probably done it already somewhere on a true race car).
Last edited by z3bra; 10-15-2005 at 03:15 AM. Reason: I felt like adding more to the message.
Old 10-15-2005, 08:02 AM
special tool
special tool's Avatar
Zebra - I looked at the nerw Hewland - unfortunately, it is only rated to 500 HP.
Old 10-15-2005, 08:45 AM
hammerwerfer
hammerwerfer's Avatar
Met a lad at the 'ring named Charlie, who had a very quick 951, and he said the simgle best mod was to swap out the turbo gearbox for an NA one. He didn't specify which one though. I know that at the 'ring I'm quite often looking for a gear somewhat shorter than third.
Old 10-15-2005, 08:55 AM
special tool
Okay - here we go:
-944NA - low R&P, but not strong
-944S - low R&P, but not strong
-944T - high R&P, strong
-944S2 - low R&P, strong
-944TS - high R&P, very strong
Old 10-15-2005, 11:33 AM
Oddjob
Oddjob's Avatar
That is incorrect. The 944S R&P (3.889) is commonly known to break when put in a 944T. This has been documented for at least 10-15 years. The S2 (3.875) is the one you want to use. It will not break.
Your mechanic either mispoke, or is completely misinformed.
Old 10-15-2005, 11:38 AM
Oddjob
Oddjob's Avatar
First and second gear have one gear of the set pair machined right into the input shaft. So the only way you can make a taller first or second gear, would be to have a complete custom input shaft made or a custom taller Ring and Pinion made. Either would be incredibly expensive and why Powerhaus II is quoting huge money for it.
Put some oversized rear wheels and tires on it.....
Old 10-15-2005, 02:23 PM
special tool
Thank you oddjob - for putting that in less ******** words than I did.
Quick Reply: Best mod yet! S2 ring and pinion
