Oil leaks near oil filter
UAE Rennlist Ambassador
Overtightening the oil filter will damage the seal enough to cause a leak (happened on the NA), also the camshaft front seal (pink one) could cause oil to seep past the covers and leak on the oil filter.
oil cooler
Originally Posted by jimbo1111
I recently replaced the oil cooler housing gasket and orings because of an oil leak. First time I ever saw an external leak on 944 t. You might want to look at that as well.
Any tips not in clarks. I need to replace motor mounts, struts, and fix an oil cooler leak. Would it be easier/better access if all were done at the same time ?
thanks
