Is this ture? comments please
Old 12-14-2005, 04:42 PM
Buckaroo Banzi
Buckaroo Banzi's Avatar
Default Is this ture? comments please
Is the below statment true?
"The ceramics are not all smooth in the exhaust ports at the exit junction...you can't sand it because it is cast that way....that is the way some (not all) of them are...if it is rough, it is not from the exhaust heat, because it does not get hot enough to melt ceramics...it is from the manufacturing process."
My understanding is the exhaust ports are to be as smooth as a baby's behind.
No rough spots and no dimples.
rebuilt head has rough spots and dimples in exhaust ports.
thanks,
Old 12-14-2005, 06:22 PM
Marks951
Marks951's Avatar
ceramic material melts at a REALLY high tempature.....try 1125 degrees CELSIUS, but pieces can break off.
Old 12-14-2005, 06:47 PM
theedge
theedge's Avatar
The ceramic should be smooth. That head is probably junk now.
Old 12-14-2005, 06:53 PM
RolexNJ
RolexNJ's Avatar
Bump, the liners need to be smooth and totally intact too. When we pulled the engine out of my car, we inspected the existing head. I couldn't believe it, but with only 30K original miles on it, the ceramic liners had 2 cracks, yikes!
Anyway the 951 heads are a dime a dozen, you can find them in junk yards cheap.
Brian: It must be cold as hell where you are now, right? Its damn cold here. I hate this crap! Sorry for the OT.
Old 12-14-2005, 07:21 PM
theedge
theedge's Avatar
Sunny and clear and apparently cold Im a cold weather person in a big way
Old 12-14-2005, 07:26 PM
RolexNJ
RolexNJ's Avatar
You can keep it, yuk! I want warm weather... is it spring already, eh?
Old 12-14-2005, 07:33 PM
theedge
theedge's Avatar
There isnt much winter in Vancouver itself, its all on the hills
Old 12-14-2005, 07:49 PM
a4944
a4944's Avatar
You think that's bad, check out this ...
Want to trade?
Mark
Old 12-14-2005, 08:05 PM
RolexNJ
RolexNJ's Avatar
That's a prime example Mark. Can you say junk?
Old 12-14-2005, 09:32 PM
Bill
Bill's Avatar
The ceramics should not be sanded, ported, filed, touched. Once the ceramic coating cracks and starts chipping as we see in this picture, replacement of the head is required. If you go to the Lindsey Racing web site, they note that prior to headwork the ceramics will be inspected. Should any cracking or chipping be found, the head can not be rebuilt.
Old 12-14-2005, 11:12 PM
RolexNJ
RolexNJ's Avatar
Bump, I went thru this with them exactly, so I know. Hence why I said 951 are cheap to get.
Old 12-15-2005, 12:27 AM
Buckaroo Banzi
Default New Pictures
Your comments please??
Old 12-15-2005, 12:38 AM
lart951
Basic Sponsor
lart951's Avatar
The one in top looks fine to me but the lower picture is that a crack?
Old 12-15-2005, 12:46 AM
Buckaroo Banzi
I think it the start of a crack or flaking? It feels rough to the touch but not jagged as you might expect from a crack..
Old 12-15-2005, 12:52 AM
lart951
Basic Sponsor
lart951's Avatar
I had a head that I pulled out of a car with 146k miles and the ceramic had a big chunck missing, the weird thing is that the turbo had no damage watsoever and neither the cylinder walls were damaged, has anybody ever documented the fact that little pieces of ceramic could damage the turbo or the cylinder walls? .
Quick Reply: Is this ture? comments please
