story teller listen up
Originally Posted by Rip It
people buy these turbo cars, 120,000 miles on the engines, throw out the cv, put an mbc in there and crank the boost all the way up to 19psi, go race it,
Guy's this is good info for newbies, we all know that cranking up the boost and not doing the things that should be done to allow that boost to be run safely is a recipe for trouble.
Yes.... I have thrown a rod, but not #2
There is a point in there somewhere, possibly that too many guys are ready to spend on go-fast goodies at the expense of proper maintenance?
One of the first things I had done to my car was to have the rod bearings replaced at the same time my pan gasket was done. It's an expensive job, but, along with the timing belt, a real achilles heel for these cars that will bite hard.
But I agree with others that excess boost rarely causes rod failure in itself. Head gaskets and top end problems yes, but not rod bearings.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
OK, here is my input – it is very hard to spin a rod bearing – the first main bearing is the only one that will spin easily, all the other bearings come in two pieces – when I try to spin them they just fall over.
I can throw a rod a good 150 feet.
As for blowing things…..well, sorry can’t answer to that one!
“I hate mechanics, their sooo full of ****”….The same is true about most customers!
I am still stuck on the title of the thread – “Story Teller Listen Up” – which one is the story teller – the author or the subject? “Story Teller” can be a compliment or a derogatory comment. not sure where you are going….
Chris White
Chris White
correct me if I'm wrong but the # 2 usually fails for lack of oil on the bearing. The boost has ZERO to do with that. Moreover this happens more with racing, and high mod applications than stock cars. So...what you genius mech said was...well nothing.
Chris White
Chris White
I would not consider you a mechanic. You are a shop, involved in everything a mechanic would tell you not to do. You track the cars, you engineer things.
Basically, you are hopelessly far too deep into your hobby! I think you know the type I am refering to though... You have to, you're in the business.
You have a point, customers are often full of it too.
~Eyal
Eyal,
I thought you got a job or did a while ago at the Porsche dealer in Calabassas as a mechanic trainee? I recall a post to that effect a while ago unless I'm wrong.
Problem:
If Eyal is a mechanic working at a dealership and Eyal says mechanics are full of **** then..
A. Mechanics are full of ****
B. Eyal is full of ****
C. All of the above
D. None of the above
Sorry Dude, I couldn't resist.
I know what your talking about. There is a P mechanic 3 blocks from my house but the guy is such a jerk and know it all that I'd never take my car to him for even an oil change.
Problem:
C. All of the above
Chris White
Chris White
yeah, you were at a dealership. big difference. my experience with my mechanic has been excellent. he does extra things for me when my car is at the shop without charging me anything, and i can always go back and hang out in the work area while they are working. they show me things that i didn't know, and explain to me the certain quirks about my car that they have discovered through having raced 944s a lot. they dont race a lot at the moment because business has picked up so much, but the knowledge i have gathered from them has been great.
as for rip it, you need to be a bit more verbose. im not saying you have to turn a 30-second story into a 30-minute story like my fiancee, but dont turn it into a 5 second story, like you did, that we cant figure out the point of. take time to elaborate and make yourself clear
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Originally Posted by Eyal 951
Chris, I meant the Porsche dealership,lude, thinks he knows all and preaches everything wrong type. ~Eyal
I would not consider you a mechanic. ~Eyal
You are a shop, involved in everything a mechanic would tell you not to do. You track the cars, you engineer things. ~Eyal
Last time I went to the dealership around here was 7 or 8 years ago – I just wanted to borrow (rent) their KLR blink code tester. I was driving the car in question and figured that they would charge me ½ an hour just to plug it in – it would have been worth it at the time. But they said that such a tool did not exist. I happened to have my factory manual so I opened it up and pointed to it….he disappeared into the back room and came out 10 minutes later…”hmmm, we might have had that a long time ago but nobody has seen it for quite a while….”. That ruled them out as a place I might refer 944 folks to!
Chris White…and yes – I am in way too deep!
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Originally Posted by Tom M'Guinn
As everyone knows, it is easier to spin the bearing if it is dry. Oil just kind of makes it stick to the table and not spin very well.
Chris White
