Hyrricane damage to my house forces the sale of my 951 and my boat
Over the last 12 months I have been knocked out of my house for 9 months with Ivan, 1 month with Dennis and a couple weeks with Katrina. My baby (86, 951) has had to be in storage. Because of the damage to my house I am forced to see her.
I bought the car in 2002 and started bringing it back to a near perfect car. With any car I buy I start by changing the parts that take the normal wear, and also fix or replace anything else I find wrong. The car has 97K original miles. The car is silver with black interrior. It has polished rim fukes, VERY cold air and drives very well. When I buy a car I start with a very clean car and love to bring it back to as close to a 10 point car as I can. I planned to keep this car as my baby but need to sell it to fix my house.
The following is a list of the work on the car so far.
1. Install “CUP” software
2. Install boost enhancer
3. Install 2 door lock arms
4. Install 2 electrical lock micro switches
5. Install premium 2-way-paging alarm with remote entry
6. Install Fosgate Amp and Wiring
7. Install Pioneer stereo head
8. Install Pioneer 4X6 door speakers
9. Install Punch 8” sub speaker and hidden enclosure
10. Install water pump (with all new hardware)
11. Install thermostat and antifreeze
12. Install timing belt
13. Install balance shaft belt
14. Install all new rollers
15. Reseal front of the engine
16. Oil change
17. Install new spark plugs
18. Install new front sway bar bushings
19. Install front brake pads
20. Install Sachs clutch disk,
21. Install new Pivot bearing guide
22. Install new pivot bearing
23. Install refaced pressure plate
24. Install clutch slave cylinder
25. Flush and fill transaxle
26. Flush brake fluid
27. Reseal the rear hatch
28. Install new hot water valve
29. Install 2 new cooling hoses
30. Install 2 reference sensors
31. Purchase washer fluid pump
32. Remove, clean and service both halve shafts
33. Install KLA Industries Camber truss (powder coat ends silver)
34. Install KLA Industries 12 point adjustable rear (non-coil over) shocks.
35. Install externally adjustable boost ****.
36. Install new Battery in 2005
My still to do list:
The car has 97K miles and has cup software and an externally adjustable boost ****.
1. High performance head gasket (the car has externally adjustable boost **** and could use a good high performance head gasket to handle the pressure)
2. Shift boot replaced
3. Drivers seat bolster needs to be re-dyed
4. The car has a scuff in the clear cote on the rubber (front passenger side) that needs clear coat touch up.
The car has been driven less than 500 miles in the last 18 months.
My house has taken quite a bit of damage from Ivan, Dennis and Katrina that require $$ to fix. I have pictures and will e-mail them to you upon request. I am looking for a good home for my baby.
I also have a 30' offshore tunnel hull boat with 2ea 225hp motors.
16. Oil change
