Intake manifold spacers (for those guys who have large turbos)
Here is the method that I came up with.
Remove driver side motor/turbo mount. Have machine shop weld 1/2" of material to the bottom of the turbo mount. Then machine 1/2" of material off of the top of the turbo mount. Use a 930 turbo base gasket, as this process will remove the O-ring groove. My turbo now sits 3/8" lower and easily clears the intake manifold. All lines to the turbo still fit fine. And best of all you do not raise the intake, and avoid hood and strut brace clearance issues. My machine shop did this work for $80.
Jeremy,
You are correct, the J-pipe is now tight at the alternator. But at mid-point not at the clamp, so installing the J-pipe is not difficult. And the exhaust bolted right up, non-issue. I have enough clearance now with my T04E that I could have only machined the mount 1/4". This would improve the clearance at the J-pipe.
TRB0 GUY
Interesting mix of ideas here.
Jeremy, a beer for your great signature!![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
The T04E I'm going to (someday) install already has some material machined off of it's compressor housing. I'm pretty sure it'll fit either way, but I'm considering putting a heat blanket on it. The only easy solution to all of this, that doesn't itch me the wrong way, would be to machine my own 1/4" spacers. That way I wouldn't have to do much machining and won't 1) raise the intake to high or 2) f*** with exhaust placement.
Now the main problem... getting the money for tuning hardware and all the other secondary parts I have to get to do the buildup how I want it.
