*price lowered* *AGAIN* custom turbo/maf/tuner/chip/injectors/ setup + other parts
afm with box (small hole in bottom of box and one of the bolts is stuck in their (so you have to swivel the top - or just cut a slit to slip the bolt from under the bolt))
stock injectors
stock wastegate
stock cycling valve
europroducts dme
I have pics of everything if you want to see them.
stock injectors
stock wastegate
stock cycling valve
europroducts dme
Are you selling seperately or keeping it all together? Hmm..do you know what a rebuild goes for? How long ago did you buy the to4e and where from?
thanks...
thanks...
the turbo was purchased from another rennlister, rob.
it had far less than 100 miles before the intercooler hose popped off and sucked in some rubber hose.
this turbo had more top-end than my 27/6 which put down the 320/350, I unfortunately never got to dyno this turbo
lindsey racing's site says $350 for a rebuild but I know it can cost more if parts need replaced...
I am trying to keep everything above the line together (turbo, maf, injectors, chip, maf tuner, 3" bend, filter)
but I will part it out if I have to
