I finally finished my turbo swap!....but now after over heating she wont start!
#33
yes, it probably is because the thermostat is not closing off the bypass in the water pump, which is not forcing any water into the engine, into the head and out the back of the head to the heater valve. Now if the heater valve is malfuntioning, that's another issue. The thermostat has to open to close the bypass port of the water pump( that little black seal inside the water pump) other wise, water primarily circulates inside the pump and is not forced to go anywhere. I think he'll be fine after he turnes it around, fills and bleeds the system.
#34
CANT GETIT OFF!!!!!!!
It took me 15 minutes yesterda now after 45 min I still cant get the damn thing off.
...just need to cool of a bit before giving it another shot.
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
#37
GRRRRRRR
well I have given up, running out of sun. Damn cant beleive I removed it yesterday in under 15 min, today I wrestled with it for 2 hours and no luck!
Well tommorow is another day....thnx guys will keep it posted..
#38
Originally Posted by Campeck
the right tools help.
do you have an inside c-clip remover with a 90 bend? napa might have one. or just try harder
lol
i have these 90^ needle nose with sharpen ends that did the trck last time...but damn no luck today.
#39
UAE Rennlist Ambassador
Correct me if i am mistaken here, but the snap ring should be set at 12 o'clock position. I followed what Mr. bruce did and didn't have any problems. It may not make any difference, but i just followed what he did and no problems:
Courtesy of Mr. Bruce
![](http://forums.rennlist.com/upload/dsc01558_copy1.jpg)
#40
Well I replaced the Thermostat in the correct way and she runs nice...YAY!!
BUT, once I turn her off I cant start her untill she is complety cool, I have to wait for hours before she starts again...damn what can it be>???
#41
Campeck Rulez
hmmm....maybe you fried something.. change your temp sensor. mayb eit got busted? and its giving to much enrichment or somethign weird? its in direct contact with the coolant. maybe start there?
#43
One of the 2 sensors that sits in a bracket on top of the clutch housing is not in proper adjustment. One of them is for referrence the other is speed. Check to make sure they are close enough to the flywheel pins so that they can still get a signal AFTER the engine is hot. The engine is expanding alot once it's hot and it pulls those snesors farther away until it gets a very weak signal. You go to start and the DME is not seeing the proper timing. Loosen the bolt that holds the bracket, take a pipe or a long socket extension and tap on the metal braket to lower towards the flywheel pins, then tighten the bolt back. Be careful not to tap the sensora as they will break, also don't tap them to close as they will hit the pins and shred the sensors upon startup. There is a proper spec in the factory manual but alas they went with my old 951 when I sold her 4 years ago. Good luck and makesure to do your research before asuming what was already there is right.
E-man930
E-man930
#44
E-man930
E-man930
hmmmm. where would I get acess to these sensors?
Underneath?
