Help installing Lindsey Racing mbc
The stock banjo bolt line is freaking huge! There's no way I can use a simple interconnect to go from that to the "standard" size vacuum line that Lindsey sends with the kit. I did the same thing with the stock wastegate line, but the reducer fit perfectly in it.
trwright@gmail.com
also check out www.photobucket.com for hosting. They auto resize anything you upload. I have been using them for a while.
UAE Rennlist Ambassador
Doc,
The lindsey racing vacuum lines will fit the stock banjo bolt, it needs some spit, and a little presuation to make it fit.
Same applies to the wastegate fitting as well.
Not in my case. The Banojo bolt line in particular is really large. I managed to stuff a larger reducer in it, it's a tight squeeze, but I think it'll hold under boost and there certainly isn't a leak there!
