Relay, under glove box????
Drive-by provocation guy
![Arrow](https://rennlist.com/forums/images/icons/icon2.gif)
There is a relay, and mine is clicking ALOT on and around start up then stops after a bit, under the glove box, on the left side almost behind the radio area.
What is it for?????
What is it for?????
could be the heater / temp solenoids, they control the vacuum signal running to the heater control valve etc. By moving the temp dial left and right you can get these babies working.
hmmm.. while we are talking about strange things in the area..
whats behing the scary looking orange cover jsut below the glove box.. I was digging around down there the other day and it confused the hell out of me..
http://www.clarks-garage.com/shop-manual/hvac-01.htm
just for clarification, items 2 & 3 in the diagram HVAC unit RHS was what i was refering too.
ok, now I don't hear the clicking and temps on AC output seem to be warmer.
I guess it is the temp solinoid. is it a relay that can be changed?
The noise is most probably the control motors for the heating/vent flaps.
They usually start audibly clicking a while before they break....
It's normal for them to move at startup. Just turn the temp **** or vent levers to test !
Tommy
Tommy
So how do I fix this??? I definetly have a clicking coming from there. A nearly constant clickin over every single little bump or crack in the road or just whenever it feels like clicking... How do i make it go away???
If it is the flap control motor(s), they will click repeatedly for a short while at startup and when changing temp. or vent settings. Stick your head under the dash and listen while fiddling with the buttons/levers !
To fix - replace the motor....
Tommy
Tommy
