Tial install alignment??
Defending the Border
Rest In Peace
Rest In Peace
![Thumbs up](https://rennlist.com/forums/images/icons/icon14.gif)
I ended up using Michelle's method because it sounded the simplest and it went together pretty easily
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
I believe you would only build boost to the spring level (IIRC standard is 0.8 bar) so you'd get only 0.8 bar of boost before dumping the rest down the tailpipe. You could run a stronger spring (I think I'll get a 1-bar spring when the time comes for failsafe mode).
This is an upcoming upgrade of mine as well - got any pics of that "trimmed" dump pipe? I'd love to see it. I may do that to mine before even starting the install just to prevent the kind of headaches everyone else seems to have with this.
If you're forcing it, it's wrong. Period.
OK now I'm lost - by "backwards" you mean that the valve opens outward into the dump pipe or you mean the opposite?
I thought on the tial gates the valve opened down into the dump pipe to prevent boost from "forcing" it open if it exceeds spring pressure (well, actually spring + signal)
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Tials open inwardly – the valve retracts into the body. The face of the vale should be the pressure side – other wise the pressure will overwhelm the spring and hold the valve closed….a bad thing.
Chris White
Chris White
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Wow, Deja vu – I just read the whole thread and noticed that I answered this question twice – back in August and again today…
Chris White
Chris White
Drive-by provocation guy
Well, I jsut reversed mine and have a air leak noise about 8-9 psi and that is all the boost it will build.
Just not in tight enough? Although could get it any tighter, or is there some other issue?
AND, when I looked at it the face of the valve was facing the pressure side, yet it was overboosting...
HELP!!!!
HELP!!!!
"Wow, Deja vu – I just read the whole thread and noticed that I answered this question twice – back in August and again today…"
Maybe 3 times will be the charm of if we could get everyone to agree on one way to install it as this thread has several ways all different.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
THE SIDE PORT SHOULD BE BOLTED TO THE DUMP, CORRECT??
