Intake Brace Bolt!
Ok, I am removing the intake to delete the cycling valve, venturi, etc. I got down to this step in Clark's procedure....
11. Loosen the intake manifold brace bolt. On normally aspirated cars the bolt needs to be removed. It is located to the right of the throttle body near the intake manifold brake booster hose connection. On turbocharged cars, the bolt only needs to be loosened and is located to the left of the throttle body under the front edge of the intake manifold.
I can't figure out for the life of me how to loosen this bolt with any of the conventional tools I have!?!?!?! Anyone got some tips?
If you have a turbo, it's a bit tricky. IIRC it's a weird size too - 14mm or something. I end up having to use wobbles on it, as well as flexible ratchet-wrenches. No easy way unfortunately.
Going with the pack
is quite monotonous.
Best tool I ever bought
1/4" drive extension with a wobbly 13mm socket on the end of it.
So from the wobble to the end of the socket is very short, so you can fit it in anywhere.
Got it from sears.
Got it from sears.
Newbies sometimes look at me weird when I mention "knowing every fastener on this car" [true for my 911 and rapidly becoming true for the 951]. Experienced guys just smile - they know.
This particular bolt is a classic. A Sears wobble worked for me, too.
I finally got it with a deep offset 1/2 inch wrench. I unplugged the turbo coolant temp sender plug and was able to get in there to break it loose. The 10mm one did not give me too much trouble although it would have been nicer if they had decided to put it on the other side instead. I'm going to cut out the bracket and make it U-shaped for next time.
Now that the intake is off the next part is figuring out what I don't need anymore.
I am deleting the CV, and I wish I could get rid of that metal tubing under there, but I need the larger one that goes from the J-boot to the air/oil separator. I was thinking of replacing it with a long rubber one but the heat from the turbo is probably the reason Porsche went with the metal tubing under there. Anyone have anything custom they are using for that?
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
Going with the pack
yeah I got rid of most everything under there, except that dang metal tubing ![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
Just for the air/oil seperator also. You are probably right about the heat, the n/a has a rubber line.
I never notice, anyway
why is this bolt a problem? ive always been able to get at it with just a 3" extension :S
i agree, though, mike, the dipstick one SUCKS. thats why i dont even have it attached.
