RE: Need Replacement Fuel Gauge
Does anybody know of an aftermarket fuel gauge that works with the factory sender?
We're finishing off the GT Racing dash and need to put in a fuel gauge. Since the factory unit is part of the cluster, we can't use that, so I'm looking for a nice gauge that we can fit into the new dash.
Anybody know of one that works?
Thanks,
Jason
Thanks,
Jason
Yes I did...I 've got Autopower gauges. The only problem is the resistance isn't the same, so the fuel gauge reads 1/4 tank higher than what's actually in your tank.
If you can live with that, then you'll be all set.
Thanks,
Jason
Thanks,
Jason
The Autometer Guage for Fords before 1989 works. e.g. Product # 4715
This has a range of 73 Ohm Empty, 10Ohm Full
According to Clarks garage the sender of a 944 after mid 85 has a resistance of 63 Ohm empty, 2.8 Ohm full. So if you you want full to be accurate, put a 7 Ohm resistor in series. If you prefer empty to be right, use 10 Ohm.
