ANY HELP WITH THIS PROBLEM
HI CAN ANYONE HELP WITH THIS PROBLEM I HAVE JUST HAD MY 951S ENGINE REBUILT.THE CAR STARTS RUNS FOR APPROX 20 SECS THEN DIES IT WILL START AGAIN RUN APPROX 20 SECS THEN DIES,AND SO ON.ALL OFF THE OBVIOUS THINGS CHECK OUT O.K,HAS ANYONE HAD THIS PROBLEM OR ANYTHING LIKE IT HAS ANYONE OUT THERE GOT ANY POINTERS TO CHECK.MANY THANKS SILVER ROSE TURBO.
Since the engine starts we know that the speed and reference sensors are good. We also know that the fuel and spark are OK. What you need to verify is that the Air Flow Meter is working properly, because this sounds like a classic case for a bad/disconnected AFM.
For some backround: When you turn the key to the 'Start' position, power goes to the DME, Fuel Pump, instrument cluster and the starter motor. When the engine RPM reaches 200 RPM, the DME fires the injectors and spark plugs, and the engine starts running. Shortly there after the DME 'polls' the AFM for a valid load signal. If the DME does not see a load signal the DME shuts the engine down.
I had something similar. Only it would run about a mile before shutting down and sometimes would be OK for a couple of days. Turned out to be a bad DME. A bad solder joint can warm up and "open". I put a timing light (all us old guys have these from the old ignition point days) on the #1 plug and watched the spark go away when the engine died.
Any help with this problem
Hi thanks for your replys the car has been off the road for approx 4 months this is how long it has took to get sorted,it is showing good fuel pressure on the fuel rail,the car is fitted with a Autothority Maf kit proir to the rebuild I had no problems with the car.
Make sure you are getting power to the MAF. Check the voltage +12V at the MAF connector (red wire).
