17" Boxtr S rims ?? best to mount on 87 951?
Purchased 2001 boxster s rims 986-362-124-00 / FR=4400n/ 7jx17-ET55/ fronts
and 986-362-126-05/ 97x17 H2/ rears
Questions:
What is the correct spacer size or correct shim size to mount the
fronts and rears?
I have mounted the rears and they appear to fit??
the fronts don't fit.
thanks,
Questions:
fronts and rears?
thanks,
You dont need spacers. What about the front doesnt fit? The only issue will be the center cap.
I would love to know where people keep turning up the 9" rears as I cannot find anyplace where they were even an option.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
When we put 951/220 front suspnsion and brakes on my 944S track car recently we had the same problem when I came to fit the track wheels as above.
The answer was 7mm spacers at the front and using a bench grinder on the dust caps to reduce the diameter a bit and chamfer them. Worked a treat.
Had to remove the 7mm rear spacers as the (drivers side in USA) would catch on the atches, which arn't rolled on the S.
HTH
Rick.
HTH
Rick.
![](http://www.cannell.co.uk/images/Cannell_web/944S%2015%202.jpg)
I had the same problems up front. The rims would not clear the dust cap.
Go to your local pep boys or Advanced auto, ask for a set of 5/16" Mr. Gasket wheel spacers (Right around $20). This will make your rims clear and fit. However, the porsche cap will not snap in all the way. Mine have been like this for a good 3000miles and have not come out yet.
Where did you get 9" rear rims?! I've only ever seen 8.5"s
EDIT: Here is my thread on the same issue.
https://rennlist.com/forums/944-turbo-and-turbo-s-forum/195975-i-need-wheel-spacers-how-big-and-where.html
Here is my solution:
http://www.mrgasket.com/ProductDetai...&minselection=
Thanks for feed back folks..
When fitting the fronts the dust cap was removed and it still did not fit flush with the hub?
spacers are needed size I think 7-8mm and longer wheel studs. Paragon has a set but for a 944
they require the spacer be machined to fit?
![Cool](https://rennlist.com/forums/images/icons/icon6.gif)
https://rennlist.com/forums/showthread.php?t=195975
some of the prices charged for the spacers is outrageous
i've got 9's on the back.
like you said 5/16 spacers only on the fronts.
87951
I also encountered this problem in the front when I switched to 996 wheels (7" front, 9" rear).
My solution was a 1/4" (6 mm) aluminum spacer from Performance Products (part #906471). They were not my retailer of choice for several reasons but the spacer is nicely machined and light weight (9 ounces each exactly). The price was just right at $26 a pair.
