Aftermarket MAF wiring Question
Old 07-15-2005 | 05:59 PM
DDP's Avatar
DDP
Rocket Scientist
Default Aftermarket MAF wiring Question
I am in the middle of wiring up a huntley maf. I am having trouble with one wire. I have all wires done except one guy. It is the black wire with the white stripe that comes off the sensor. Where does this one go to on the DME? What is its purpose? Thanks
Old 07-15-2005 | 07:11 PM
DDP's Avatar
DDP
Rocket Scientist
I don't mean to rush, but I kinda need this soon. thanks
Old 07-16-2005 | 12:12 AM
awilson40's Avatar
awilson40
what pin number or letter does it connect to on the MAF
Old 07-16-2005 | 12:25 AM
DDP's Avatar
DDP
Rocket Scientist
Not sure....
Old 07-16-2005 | 12:42 AM
DDP's Avatar
DDP
Rocket Scientist
Pin D I think.
Old 07-16-2005 | 01:31 AM
Claus Groth's Avatar
Claus Groth
I don't know if this will help. I have a bullet MAF from Lindsey Racing / Pro-M Racing. It has four wires with the connector labeled A B C D, A is closest to the inlet. A is 12V switched power. B & C are both ground. D is the output signal that goes to the DME pin #7, or to a signal conditioning module, if you have one.
Old 07-16-2005 | 01:41 AM
DDP's Avatar
DDP
Rocket Scientist
Do you know what color the wire is that D goes to? What color pin 7 is? Thanks
Old 07-16-2005 | 01:46 AM
Claus Groth
Yea. I still have my notes next to me. DME pin #7 is a 1mm diameter green/red wire.
Good luck.
Old 07-16-2005 | 01:50 AM
DDP's Avatar
DDP
Rocket Scientist
Thanks.
