"MISTAKE" at the gas station
Originally Posted by streckfu's951
How does Toulene come? 5gal cans or smaller?
What's it's intended use? As a paint thinner or what? Just curious.
Hitsquad Ninja
i did some searching and did some reading, but how much tuolene or xylene can be safely used as a percentage of the normal gas in there? that's the main question i have. vp103 is the way to go but since tuolene and xylene have such high octane ratings, i was wondering what could be done with mixing possibilities.
HEy guys, yea I only put 4 gallons of 87 in my car which got to to 1/4 tank. I do have APE stage II, so I thought I needed to get higher octane in me asap. Im ok now, I filled up with 91 aswell as puting in some octane booster. Thanks everybody
At the Home de blow the xyelne was I believe 10 buck per gallon ?
What does the toulene cost at Sherman Williams ?
regards
Ed
regards
Ed
1 Post
regards
Ed
regards
Ed
Monkeys Removed by Request
go a paint store it will be much cheeper.
Toulene is about what? 114-116 octane. So you dont need much to severly bump your octane rating up multiple points...unless you are running a full tank. Maybe a 20-30% mix of toulene with 91. I buy 93 at the pump here.
