Oil drain plug
Old 07-14-2005, 02:56 PM
ibkevin
Defending the Border
Rest In Peace
ibkevin's Avatar
Andrew,
Two things scare me about that valve 1) Catching some road debris and winding up on the side like Ted, 2) Someone with ill intent and a couple moments alone with the car discovers/knows that valve is there!
Both justify my couple extra minutes and grumbling to fuss with an oil plug.
Old 07-14-2005, 03:32 PM
z3bra
z3bra's Avatar
I like this setup for a quick drain coupling.
http://www.racerpartswholesale.com/aero4.htm
It's by Aeroquip but it's a pain to find a link to it on their site so I cheated a little bit.
And I wouldn't worry too much about malicious oil draining. If someone wants to do it bad enough it's nothing an adjustable open end wrench or pliers can't handle. They still have to reach under there which aint gonna happen without jacking it up or some other kind of under vehicle access.
Old 07-14-2005, 03:39 PM
EdC
EdC's Avatar
Talking
That aeroquip "thingy" looks neat. Especially that "male-female coupling". Nothing like a XXX oil change to get one's motor running.
Old 07-14-2005, 03:41 PM
z3bra
z3bra's Avatar
Heh, it's also about $25 bucks for each half of the set but you're right it is pretty sexy (in many ways).
Old 07-14-2005, 05:37 PM
TRWright
TRWright's Avatar
Originally Posted by brad-cam
It is a M20 x 1.5 mm. The hex socket size may vary depending on the plug (might be 15 mm).
Thanks, that was exactly what I needed. All fixed! The car runs great!
Old 07-14-2005, 05:59 PM
Jon Moeller
Jon Moeller's Avatar
Ted,
When will you be swinging through Albany? Very interested in seeing your results.
I want my engine stand!
-Jon
Old 07-14-2005, 06:04 PM
TRWright
TRWright's Avatar
I was actually going to head down tonight, but my better judgment will not allow me to drive the car that far until I put a few miles on it around town! I will be down in the next few days, though. I will give you a call. Thanks again, bro!
Quick Reply: Oil drain plug
