CT Emission Test Results v/Vitesse Chip !
Old 06-23-2005, 09:52 PM
GreyDog
GreyDog's Avatar
Default CT Emission Test Results v/Vitesse Chip !
Good News !
I brough my mostly stock 951 to a test center (Goodyear tire shop recommended by my mechanic) for the new test regimen.
Car is a 1986 944 Turbo, stock except for Vitesse <15psi chips and a boost enhancer. I dialed the LBE down to 11psi setting to try to keep boost lower than I typically run at.
Results:
HC CO NOx
Test Limit: 200 .64 1400
Emission Results: 86 .41 551
Car was run on the rolllers at 2400 rpm, in second gear (I believe). The tech ran the engine up to 2400 rpm nice and slow and held it dead even, no blipping. I was not sure what the Vitesse software would do in the testing, but Johns handi-work came through !
Anyway, just wanted to share, I was REAL happy to see the tech give the thumbs up, now I can get that new steering rack I've been dreaming about (in meetings at work) !
- Later.
Old 06-23-2005, 11:22 PM
fast951
fast951's Avatar
GreyDog, Glad everything went well. Thanks!
John
Email
www.vitesseracing.com
Old 06-24-2005, 02:52 AM
Ben Z.
Ben Z.'s Avatar
Do you have a cat? Would there be a chance of passing without one? Thanks.
Old 06-24-2005, 11:29 PM
docwyte
docwyte's Avatar
My 951S passed emmissions with the welt chips and no cat with flying colors. Depends on the state and test tho, where I am it's a simple sniffer test. I'm fairly sure I wouldn't pass on a dyno test...
Old 06-25-2005, 02:59 AM
will951
will951's Avatar
Darn....I just went through. Guess that means I didn't need to swap my chips before I went....
I passed w/ 29, .18 and 611 on the same scale.
Old 06-25-2005, 07:00 AM
special tool
special tool's Avatar
I am going to run mine through CT emissions in the same configuration that I dynoed it - if it passes, I am going to laugh my *** off.
Old 06-26-2005, 05:41 PM
GreyDog
GreyDog's Avatar
Ben Z, I do have a cat installed.
Will951, I live in North Madison (off Rt 79), I think I've seen you around in Durham. Look/listen for my Red 951 w/the car seat in the back, and a Borla....
- Later.
Old 06-26-2005, 06:00 PM
Ian Carr
That Guy
Ian Carr's Avatar
well i have no cat and my car runs crappy... can't wait to see what happends.. o yeah i was supposed to go in last week
Old 06-26-2005, 11:43 PM
will951
will951's Avatar
- Later.
Cool....I live off Rt. 77..... less than a half mile to 79 via Sand Hill Rd. Spend a lot of time on 79 cycling.
I dig the car seat!!
See you around!
Old 06-27-2005, 12:31 AM
Ian Carr
That Guy
Ian Carr's Avatar
Will you like like a hour from me
Going to 944 fest by any chance?
Old 06-27-2005, 10:06 AM
will951
will951's Avatar
How long is the drive? And when is it? I'm shot for the month of July....well....most of it....
Quick Reply: CT Emission Test Results v/Vitesse Chip !
