Can you log boost with a LM-1?
Part of the IN Crowd
I just ordered LM-1 with RPM. The RPM module has provisions for RPM logging and 4 extra inputs.
I was thinking TPS could be one but how would I set it up to log boost?
Buy a pressure sensor and put it in the intake or what?
When you say MAP sensor are you talking about the traditional MAP that is used to meter fuel or is there a different needed for boost pressure?
I have a MAF getting ready to go onto the car.
I just mean a MAP sensor to describe a sensor measuring the manifold pressure, there is no need to use it for air/fuel control if you have a MAF. Maybe you could T-into the KLR boost line or something?
http://www.innovatemotorsports.com/f...Boost+Pressure
Had the on the wrong post. I think fen and I are the only ones who are following this.
Pic a suitable MAP sensor (2.5bar is recommended). Keep in mind that most MAP sensors work on 5Vdc (instead of 12Vdc).
